Machine Vision
how to set up Serial Communication
I just acquired a new camera but the camera manufacturer does not provide me with camera control utility.
So, I downloaded Putty to establish serial communications with the camera through the frame grabber, and I am not sure what to put in as my Serial Line.
When I first open Putty, my default serial line in COM1 BUT I don;t think it's correct.
Could someone please help me what should I do to establish serial communications with the camera?
Thank you
(5,438 Views)
Can you get the camera to grab in max? What is the interface name mentioned in max?
(5,425 Views)
Yes I can get the camera to grab in max. Also the interface name img0
Pat
(5,415 Views)
Exactly what hardware are you using and how do you have everything connected? What do you want to be able to do via the serial communication?
-Zach
(5,388 Views)
Hi Zach,
The camera is connected to the frame grabber via Camera Link Cable (Base configuration). The camera manufacturer does not provide me with camera control utility and they recommend me to use any Terminal Program (e.g. HyperTerminal).  I decided to use Putty to send serial commends to the camera to configure. When I first open Putty, my default serial line is set to COM1 BUT I don't think it's correct.
I don't know if Putty is the right choice for this and I am not sure what I should enter instead of COM1 to send the commends.
Thank you
(5,379 Views)
I cannot give recommendations on how to use other programs to communicate with the camera. LabVIEW has the ability to send serial commands, but if you want to use something like Putty, you would need to consult their documentation. A quick Google search yielded the following references:
http://the.earth.li/~sgtatham/putty/0.60/htmldoc/Chapter3.html
http://www.vaisala.com/files/Using%20PuTTY%20terminal%20application%20with%20Vaisala%20instruments.p...
-Zach
(5,355 Views)
Pat,
The IMAQ boards do not emulate a virtual serial port (e.g. COM1). They are accessible via the IMAQ API, serial commands embedded in IMAQ camera files, and also the standardized "clallserial" API that most framegrabbers support. Typically the camera vendor provides some configuration utility that accesses the camera via the clallserial interface.
In this case, you would probably want have your application send serial commands you need.
Eric
(5,348 Views)
