Machine Vision
how to solve error code -1074397179 in Imaq Attribute VI
I keep getting error message (-1074397179) when I run the imaq attribute VI. What should I do to solve this problem? What are the parameters that i can change to solve this. The error message gave this as img_err_par1. But I have no idea how to solve this problem.
(2,952 Views)
I compared your attribute VI to my own (which is IMAQ 2.6 and working great) and the only differences are in the Attributes input and the Type/Attr/ID input. I have attached my version of the VI in LabVIEW 6.1 below. Try using this and see if it gives you the same errors.
Hope this helps-
Julie S.
(2,952 Views)
