Machine Vision
how to use 12-bit tiff image in imaq?
does labview support 12-bit image?
Message 1 of 8
(5,356 Views)
Look here:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=5065000000080000007F510000&UCATEGORY_0=_15_&UCATEGORY_S=0
Message 2 of 8
(5,356 Views)
Yes, I know LabVIEW & IMAQ support 12-bit image
in acquiring images/movies. It seems it convert them
into 16-bit inside, and save them into 8-bit or 12-bit
images.
My problem is I have some image files from some camera, and are 12-bit image files.
"IMAQ read from file" can not open them now.
Message 3 of 8
(5,356 Views)
How about posting a sample image file so other people can try opening it? It is hard to figure out what is wrong without an example.
Bruce
Bruce Ammons
Ammons Engineering
Message 4 of 8
(5,356 Views)
Ok.
It can be opened in IMAQ. But details lost,
Message 5 of 8
(5,356 Views)
I tried to open the image in several different programs but had no success.
This looks like it is a proprietary format that only works with the camera and whatever software came with it. I'm not sure how it could be read into IMAQ.
Bruce
Bruce Ammons
Ammons Engineering
Message 6 of 8
(5,356 Views)
Thank you for tour attention.
I downloaded the file and test it.
I can open it properly in ACDsee,IrfanView,GraphicsMagick Display.
I can also open it with Labview+IMAQ not correctly.
The Details are lost.
Message 7 of 8
(5,357 Views)
I revisited this thread after one year.
I found that some format convertor program, can convert 12bit tiff to 16 bit, then opend by IMAQ
without any problem.
such as imageMagik or graphicMagik
Message 8 of 8
(5,249 Views)
