Machine Vision
how to use Labview buttons to open + capture the picture and close it ?
now i can use it to capture the picture only one time ... and if i press the OK button again the program will be unuseable then i've to stop the operation and reopen it
also i want to know whick function to use to make the camera stop by using stop botton
(5,408 Views)
So you want to capture, process, result and continously go on right. Put all the image processing in a sub vi. Bring the subvi inside the while loop. Stop the loop only when u want to quit and cloase labVIEW. Right?
(5,405 Views)
i want just capture , process, result but don't need to continously go on but if i click the OK button again to make the program capture , process, and result the new one
and the stop button is to quit Labview
(5,403 Views)
Simple. Use a case structure inside the while loop. Use two buttons. Select ok to capture image. If you dont select any button the while loop will loop around the default case so make it empty. Connect the stop button to the while termination. Got it?
(5,401 Views)
so which to put in the Case structure ? the whole program or just the function which use to capture the picture ?
(5,396 Views)
See the attached vi
(5,394 Views)
tnx for ur help muks i'll try it tomorrow cuz i don't have the camera right now.. can u @ my email-address : goodguyfromhell@hotmail.com so i can ask about this labview problem more easier
(5,390 Views)
