Machine Vision
how to use OCR Training Interface in c#.NET Application
In C#.NET Application needs to use OCR Training Interface. Please share some sample programs for this.
(4,756 Views)
The OCR Training Interface is an executable utility included with Vision Development Module.  With it, you can prepare OCR trining files for unsupported fonts.  Using this utility will shed light on how to proceed in writing your own routine using the VDM.  AFAIK there is no example that demonstrates this.  Search examples.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(4,746 Views)
 OCR Training Interface wizard can use only Vision Assistant or some other application
(4,738 Views)
