Machine Vision
i am using Pattern matching using vision assistant . its able to detect the temple which created while configuration
Hi all ,
         i am using vision assistant to do patten matching . its able to find the pattern with created template in vision assistant .
        if i load some other pattern is not detecting ..
         i have attached my vi file
Message 1 of 1
(5,571 Views)
