Machine Vision
i have PCO 1300 camera whihc is not seen in measurement and Automations it is a ieee 1394
What os are you using?
(4,728 Views)
If your os is not vista then this will help
(4,726 Views)
Hi Reghu,
     You problem is very common. Please check the following:
  • Software Considerations
  1. Make sure that you installed NI Vision Acquisition Software and it is activated.
  • Hardware Considerations
  1. Make sure your NI PCI framegrabber is mounted correctly in PCI slot (you have one, don't you?)
  2. Make sure that Firewire Cable is reliable as this was my problem in the past.
  3. Check that your camera power cable is plugged correctly.
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(4,723 Views)
Dear All,
It looks like the Cooke PCO cameras are not compliant with the IIDC standard.  Apparently, they will be releasing LabVIEW drivers for the PCO firewire cameras in the near feature, see http://www.cookecorp.com/cooke/php/support/third_party_1-en.php?01040401&lid=186.
-Robert
Robert Eastlund
Graftek Imaging, Inc.
Phone: (512) 416-1099 x101
Email: eastlund@graftek.com
(4,717 Views)
Yes Robert is indeed right
Driver software for LabView
are available for free!
Please, approach sales people at PCO AG
or at The Cooke Corporation, www.cookecorp.com
The software will soon be available for download.
as mentioned try contacting the sales person.He might send you a cd
(4,714 Views)
