Machine Vision
i want view data coming on camlink but i am unable to set cam setting
(3,942 Views)
Hello Ravikrishna,
Pls share details about the hardware and software configuration at your end. Also tell us what you have tried till now.
Cheers!
Jayanth
(3,914 Views)
hi Jayanth,
               i am generatting emulation of camera on fpga board (generation of cam signal) and connected to the frame grabber for acquire image .
               In this i have taken care of all signals that required as per camlink. To proced further i have debug using frame grabber.
               can u suggest me how to proceed further.
thanks
(3,907 Views)
Hello Ravikrishna,
I would need to understand your system in place and your ultimate objective before I have help you. Pls give me complete information about your hardware/software. Your ultimate objective of this project and what is it that you mean when you say debug? What are you debugging??
Cheers!
Jayanth
(3,902 Views)
ok,
       i am using fpga board for emulation of camera signals (FVAL,LVAL,DVAL,DOUT,SPARE) according to standard CV-A33CL.  camlink connector form emulation board is connected to framegrabber (PCIe1427) software using is  Measurement & Automation IMAQ , NI camera file generator,Vision builder AI.
i have taken care emulation of camera signals as per  CV-A33CL. but  unable to acquire image file on software (NI)
regards
Ravi
(3,898 Views)
Hello Ravikrishna,
I understand you have already got in touch with the National Instruments India Applications Engineering team on this and they are working with you.  So moving forward the replies to your query will come from the support team directly to you.
Cheers!
Jayanth
(3,893 Views)
