Machine Vision
image acquision using 1473 fpga frame grabber
Hi everyone,
I am trying to acquire images using NI-1473 FPGA frame grabber and Dalsa camera. I could not grab any images just by running the examples shipped by Labview, and I have these questions:
1- Do I need a .ccf before acquring images prior to using a FPGA frame grabber?
2- Does it mean that I need to set up my camera beforehand with a normal frame grabber + MAX and create a .ccf and then deploy it using 1473 card?
Camera model: Dalsa (Piranha HS HS-80-08Kx0), 8taps full camera link, TDI/Area scan
thanks in advance for your help.
(3,674 Views)
1,No need ccd file
2,just setting 1473 fpga code which camera data format match your camera type。
(2,541 Views)
