Machine Vision
image buffer
I just started using the PC1411 card & loaded NI-IMAQ.
I'm now playing around with the examples given in C.
From the "Grab" example in MSVC, is the image stored in ImaqBuffer?
What does this buffer look like?
As in how do I get, for example coordinate (x=12, y=23)   HSL=? R=? G=? B=? the values for the pixel.
Hope you can help. Thank you.
(3,419 Views)
Hi Vic-SOEM,
Thank you for posting to the NI forums! I noticed you posted the same forum post here, please refer to that thread for the continued discussion of your issue. We ask that you only post a topic once to keep the forum from being filled with redirects. An NI Application Engineer will answer your forum post if it has not been replied to after one business day, therefore posts on Saturday and Monday will receive an answer at the same time.
Maclean G.
Applications Engineering
(3,389 Views)
