Machine Vision
image calibration
I used to use vision calibration training tools need to calibrate and save .png , and then in the vision assistant in the preparation of procedures, I would like to ask the labview image IMAQ Lane directly generated calibration map code, or will training Calibration steps to generate labview VI, similar to the assistant into vi code the same function?
thanks !
(3,028 Views)
hi
 i think the next way will be better,and will save a lot of work
(2,907 Views)
