Machine Vision
image mask
Does anybody know if it is possible to rotate the image mask in NI Vision Assistant?  If yes, how?  Thank you!
(3,453 Views)
Hi Van-Rob,
There is not a way to rotate a mask within Vision Assistant.  Typically, Vision Assistant is used to help users develop a vision routine and then they move their code into LabVIEW or some other programming environment.  If you need a rotated mask for testing purposes, a possible workaround is creating a rotated mask file in another program.  Once this file is saved, you could then use it in Vision Assistant.  Once you move into a programming environment such as LabVIEW, you will be able to rotate the mask on the fly.  If you were hoping to run your Vision Assistant script as a standalone program, I encourage you to look into Vision Builder for Automated Inspection, which is intended as a standalone program.
Ryan M.
National instruments
(3,439 Views)
