Machine Vision
image processing
We are designed to image processing program using USB camera.
At the display panel showed the in process image.
We want to image processing disign.
We want to arranged image process part into the back and image output part into the front.
In this case, The front part is connected but dispay part is showen processed image.
What's this problem?
So, We tried to solve this problem. One of the solutions, the one is using two "While pattern" that,
one is image processing part, the other is in process and display origin image. But it did't work.
Because an error, call by "Multiple Device".
2.How can we do?
(3,534 Views)
I am sorry but I am not very clear about this. Can you try explaining it in other words?
(3,524 Views)
Sorry Jacky, but could you explain this in a better way?
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(3,483 Views)
