Machine Vision
image subtraction
I have the background image which is 1500x1200 and i need to subtract an image which is not not exactly the same size with this.The image in 1500x1100 and it will vary.I need to subtract the image and fill black as compensation.Any idea would make my task a lot easier.
(4,176 Views)
Hi muks,
you can resize your smaller vi to the original size, make your image subtraction and change all pixel inserted before with black.
Mike
(4,175 Views)
yes mike i can do it for 2 images but i want to do it dynamically for real time images
(4,167 Views)
Hi muks,
how often/fast is real time in your case? Smiley Wink
Mike
Message Edited by MikeS81 on 07-11-2008 12:45 PM
(4,164 Views)
By realtime i mean the incoming images. While aligning the image's aspect ration will change considerably.Time is notatall  a criteria mike
(4,159 Views)
