Machine Vision
image to array
hi
i have to convert an image into array,, i have done this by using imaqcolorimagetoarray vi. but it gives a 2d array but in real, image is a 3d array with 3rd dimensions for rgb.
how is it compared with the 2d array of image in labview.
how can i know about rgb values?where rgb image's pixel values are shown by  2d array.
but in matlab the same image is shown in 3d arrray...
(4,804 Views)
In fact, this function return an array where the 3 pixel values are bundle to a U32 value.
So you have two options, you can split this U32 into 4 U8, where you will find your Re, Green and Blue channel.
Or you can first extract the color planes into 3 grayscales images before converting them into separate arrays.
See the attached vi with both options.
Regards
(4,790 Views)
hey! thnx dear for replying
but i have lv 11 so dis vi ix not compatible with lv11.. kindly convert it to lv11 or lower versions
thnx... m w8ng
(4,782 Views)
Here it is.
Regards
(4,756 Views)
thnx alot 🙂
(4,746 Views)
