Machine Vision
imageTOimage background
i was wondering if anyone had a similar problem as me - i am using "IMAQ Image to image 2" to join a smaller (static) image and an image from a live stream (webcamera) as is shown in the image below.
The diffrent image resolution is clearly responsible for the "background" area which is surrounded with a green rectangle (overlaid with an image editor to present my problem more clearly). I am wondering why there are periodic stripes and not just a black background instead?
Thank you and best regards,
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,076 Views)
Hello! Klemen
I think that you will never ask question, and provide answer for ever. Ha Ha!
I test  "IMAQ Image to image 2", I can`t put the smaller picture in the left, can you upload your code?
CLD
CAU
(5,061 Views)
Accepted by topic author Klemen
Hello!
Today i tried it again with the same code and the background is indeed black. I really don't know what the problem was???
Anyway, looks like it is solved, but without a solution. Smiley Happy
Thanks and best regards,
K
(5,055 Views)
