Machine Vision
imagen acquisition by pressing one key
 Hi, i need to do a vi with the following requiremets:
i have to start a camera, when pressing the key CTRL the camera must grab and show the image and  when i release the key CTRL must show the last frame. If i repress CTRL key restart to grab and so on...
any idea?
thanks
(4,184 Views)
Accepted by topic author deveron
easy one
use Imaq assistance inside the case structure with until when release bottom
go to this bottem property and use key focus to Ctrl
this code should be inside the while loop for continues run
(4,173 Views)
Done this. thanks!!!
(4,122 Views)
you welcome
(4,093 Views)
