Machine Vision
imaq 1394 visual studio 2010
Kyle,
I don't see the exmaples folder in NI-IMAQdx. I ran IMAQdx 9.1.1 installation and I didn't see examples being included anywhere.
What is the difference between NI-IMAQdx and Vision? Both of them are in National Instument folder. For my development which should I use and how do I choose? It seems all the controls are registered and I can't do anything about it.
Meanwhile I am looking for the examples you mentioned.
Xianmin
Message 11 of 18
(1,255 Views)
After I removed NI completely, my pc is dead. It can't boot it any more.
Message 12 of 18
(1,250 Views)
Did you consider upgrading to Vision Development Module 2009?
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
Message 13 of 18
(1,240 Views)
I donwloaded everything about 2 weeks ago, I believe I have the latest.
Message 14 of 18
(1,232 Views)
Hi Xianmin,
This article should give you the differences between IMAQdx and the Vision Development Module:  http://digital.ni.com/public.nsf/allkb/45A5682F377996BB862572B50072787F?OpenDocument
Message 15 of 18
(1,220 Views)
Kyle,
I am downloading vas2009. NI-IMAQdx apparently is not in the VDM2009, or the installation may have problem. In any case I don't have it installed after I installed VDM2009.
Xianmin
Message 16 of 18
(1,216 Views)
VAS 2009 will install IMAQdx and nexessary drivers necessary for your camera to appear in MAX. VDM 2009 has .NET control to acquire easily from your camera.
Assistant Lecturer
Message 17 of 18
(1,205 Views)
Not quite right...
Vision Acquisition contains the IMAQ and IMAQdx drivers to acquire from cameras.
Vision Development Module contains all the algorithms for machine vision and image manipulation (only a subset of such VIs are present when you install just Vision Acquisition).
Each of these two items contains their respective .NET interfaces when you install them.
NOTE: VDM also installs a legacy ActiveX/COM DLL (CWIMAQ) that exposed Vision Development functions as well as some basic image acquisition though the IMAQ driver only. This component is deprecated and should not be used. You should instead use the native .NET interfaces from the respective software packages.
Eric
Message 18 of 18
(1,204 Views)
