Machine Vision
imaqCopyRect Question
Is the  imaqCopyRect() function only intended to be used with the source and destination images having the same dimensions (or at least the same width)?  As far as I can tell, the function only seems to work properly when that's the case.  Thanks.
(3,200 Views)
Nevermind, I think I figured it out.  When calling the imaqGetImageInfo() on the resulting image, you have to pay attention to the pixelsPerLine parameter which may not be the same as the xRes parameter.
(3,198 Views)
