Machine Vision
imaqDisplayImage
can someone please tell me how to display an Image that is unsigned char when the function
imaqDisplayImage( Buffer, 0, TRUE);
gives me the error Type error in argument 1 to imaqDisplayImage found pointer to unsigned char expected pointer to const Image
So how do I use this function can I convert my unsigned char image to const Image?
thanks,
JS
(4,450 Views)
Hi
you called
but the arg 1 is of type cwImaqImage and not unsigned byte pointer!
i displayed a image buffer with calling
  imaq1394plotDC(HandleToCanvas, buffer, 0,0,width,height,0,0,0)
or u use the cwImaqViewer
and attach a cwImaqImage to.
hope this helps
(4,440 Views)
Sorry to bombard you with such easy questions but is that 1394 lmaq library part of the IMAQ or VISION or what because I can't seem to find those libraries and I have the VISION and IMAQ.
thanks,
JS
(4,427 Views)
JS,
    The IMAQ 1394 driver is included with a driver set called Vision Acquisition Software.  It is also possible, though, to get the drivers individually.  It sounds like you have NI-IMAQ but not NI-IMAQ 1394.  The 1394 driver is not a free driver, but you can download the driver set and try it for 30 days.  Let me know if you have more questions!
-Allison S.
Calibration Services
Product Support Engineer
(4,421 Views)
