Machine Vision
imaqReadFile raises Microsoft C++ exception: GRLIBError_enum when reading 16bit TIFF files
I have to read 16bit tiff files into a imaq images. This I do in Visual C++ like this:
    Image* test = imaqCreateImage(IMAQ_IMAGE_I16, 0);
    int res = imaqReadFile(test, "d:\\error.tif", 0, 0);
res is "1" which indicates that the image has been loaded correctly. But the debug output prints 4 Errors:
    First-chance exception at 0x7c812a5b in Test.exe: Microsoft C++ exception: GRLIBError_enum at memory location 0x0012cb88..
Test.exe: Microsoft C++ exception: GRLIBError_enum at memory location 0x0012cbe0..
The error also occurs with the ..\National Instruments\Vision\Examples\MSVC\Load And Display\ example. Still the example program displays the image correctly.
I attached a 16 bit tiff for you to try. I cannot just dirtily catch the exception because after some 50 images my program is stopped with the message that the heap is corrupt.
Hope for your help,
Fabian
(4,267 Views)
Hello Fabian,
often a first chance exception does not mean their is a problem in a code. This message let your know that an exceptional situation was encountered and was handled.
Probably you could disable this on the debugger's configuration.
Cheers,
AmirG
(4,242 Views)
