Machine Vision
imaqRotate2 fails with 1600x1200 images again
The last solution is not working. It only takes more cycles to fail.
(3,074 Views)
Strange.
If you need to have only 90 / 180 / 270 degrees rotation, then I will suggest to stay away from imaqRotate and develop your own rotate function. Its only few lines c code.
Andrey.
(3,070 Views)
Hi Garcia,
Please try not to create multiple threads with the same question.  Duplicate Post.
Adam H
(3,048 Views)
