Machine Vision
imaqdx win7 format 7 mode 0 (AVT Pike F145B)
I am using an AVT Pike F-145B under windows7 (32bits). With Measurement and Automation Explorer 4.7.7 I can grab images if I use another video mode than format 7, mode 0 (which is the video mode I need!). If I use this video mode (format 7, mode0, 1388x1038), it is as if something was not well synchronized and the acquired frames are mixed up.
Does someone has a clue for this issue?
(3,427 Views)
Hello Gege91,
Are you using the latest driver available in order to be sure that it's not coming from that point. Did you try it also another computer?
Regards
(3,417 Views)
I installed NI Vision Acquisition Software March 2011. And I've already tried this camera with another computer but under WinXP, I do not have another computer under win7 available now for further tests.
I think I will try to use my camera with AVT SmartView and see if there still is something wrong.
Regards
(3,414 Views)
I've just noticed I am always using my camera with "PacketSize"=4095 bytes, I've tried other values and while this parameter is smaller than ~4016, I do not have my problem anymore.
Is that because I am using an IEEE1394b camera with IEEE1394a on my computer?
I've never had this sort of trouble under Windows XP...
(3,409 Views)
