Machine Vision
incorrect xml error
This is related to running of NI IMAQ version 4.3.0f0  with a GigeVision Compliant camera. I run into an incorrect xml related error  even thought the xml on the camera is correct.   I am using a Windows XP Operating system
It is as though NI has an older version of xml on my computer  from a previous run with a different Gige Vision Compliant camera..Is there a certain application data folder that National Instruments IMAQdx software storesolder xml in . If so, could you tell me the path to this folder  under  Windows XP so that I can delete it?
 I looked under    all sub directories of     C:\Documents and Settings\ All Users\ Application Data \ National Instruments \  but did not find any xml directory to delete.
(3,739 Views)
The folder you are looking for should be located at:
'Drive':\Documents and Settings\All Users\Documents\National Instruments\NI-IMAQdx\Data
Let me know if deleting and letting your camera regenerate the file doesn't work.
Best Regards,
~Nate
(3,724 Views)
Thanks a lot, I will try it out.
(3,720 Views)
Thanks a lot , it seems to have worked!
(3,717 Views)
