Machine Vision
installer with usb drivers
Hello all
I have LV8.0
I want create the installer with USB drivers
I added the  USB drivers to the installer.
when I installed installer on the PC with LV - all was worked.
On the another PC  without LV I received the error from USB driver SYSTEM error ( on this PC I copied the file ImaqDirectShoudll.dll)
What must I add to installer else.
Best regards
Iskander
(3,648 Views)
You probably just need to register the DLL. See this Thread for details:
http://forums.ni.com/ni/board/message?board.id=200&message.id=5991&query.id=9297#M5991
(3,642 Views)
Thanks Brad for the help
All are working
Regards
Iskander
(3,618 Views)
