Machine Vision
iris recognition wrong intake of image
i am doing iris recognition using labview as my final year project. i got a file of the same from one of the discussion forums but i am not able to run it. the image is not getting inputted so kindly view the file and suggest me solutions for the problem. i inputted .bmp files. i am using labview 2012 and vision devolopment module.
below is the file.
kindly help me..
(4,137 Views)
i am also using the same file i need to create an iris database and output the personal details when an input is given .. can anyone help me???
(4,100 Views)
What error are you getting ?
Silver_Shaper | CLD
(4,089 Views)
A SubVI "IVA GRayFilters-NthOrder.vi" is missing, otherwise it should work properly. You should also mention the forum where you found the file.
Ing. Jonathan E. Cruz Ortiz
ENERGÍA PROACTIVA S.A.S
Cel : (+57) 3173669343 - (+57) 3124451894
(4,084 Views)
No its not the actual problem and its an built in LV Function can load from different location based on LV version.
Silver_Shaper | CLD
(4,080 Views)
Ok Silver_Shaper , thanks for the clarification.
(4,076 Views)
