Machine Vision
label inspection system
I'm developing a "label inspection system" , comparing the label acquired from the camera with one as a source image (.bmp file).
Could you please suggest some methods that can help correcting the brightness of the image acquired from the camera with the source image??
I also have proplems when the acquired image not lie in the same angle with the source image file.
Thanks for your helps,
a_p_c
(2,954 Views)
a_p_c,
Can you post the source image and a couple of the images acquired from the camera?  It will be easier for me to come up with a solution for you if I have your photos.
Lorne Hengst
Application Engineer
(2,930 Views)
