Machine Vision
large structuring elements
Hi!
I'm working on an application in VB.net. I woudl like to use  GrayMorphology() with a structuring element of 40x40pixels. Here is what I do:
 Dim struct As New NationalInstruments.CWIMAQControls.CWIMAQStructuringElement
 struct.SetSize(40, 40)
 Vision.GrayMorphology(Image1, Image2, CWIMAQControls.CWIMAQGrayMorphOperations.cwimaqGrayMorphClose, ElemStruct)
previously i do Image2.BorderWidth = 22
the closing does not work.
Thanks.
(4,058 Views)
In LabVIEW it works.
I'm not expert in VB, but I guess that Image2.BorderWidth = 22 may not really (means physically) set the border width.
Look for the function named "ImageBorderSize" or something like that.
In additional, all elemenths (or some) in Structuring Element should be equal to 1. If all of them are zeroes, then nothing will be changed in image.
Andrey.
Message Edited by Andrey Dmitriev on 06-10-2010 07:00 PM
(4,042 Views)
Sometimes the structuring element needs odd dimensions.  Even dimensions confuse it since there is no center pixel.
Bruce
Bruce Ammons
Ammons Engineering
(4,028 Views)
I found the solution!
The border width has not to be defined on the destination image but only on the source image.
For information, Image.borderWidth works fine.
Thanks for your reply!
(4,018 Views)
