Machine Vision
list multiple firewire cards
I am  developing a 10 camera system using multiple IEEE 1394 (firewire) cards ...
How do i list the firewire cards connected and which camera is connected to which card ...?
PLs reply..
Message 1 of 8
(4,946 Views)
I don't know how you would list the attached firewire cards (can you explain why you need to do this?). But the following should help finding the attached firewire cameras:
Programmatically Finding Attached IEEE-1394 Cameras
Message Edited by Adnan Z on 05-11-2009 07:02 AM
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 2 of 8
(4,934 Views)
To check which card do not have sufficient bandwidth  to support the cameras connected
Message 3 of 8
(4,927 Views)
thanks .. but that is not what i require...
 help me by suggesting how to get the card details from the camera properties
Message 4 of 8
(4,901 Views)
What are you using on the driver/software side for interaction??
regards,
Turbo
Message 5 of 8
(4,898 Views)
I am using NI IMAQdx driver for the camera..
Please suggest some way to identify ,the card to which the camera is connected
Regards
Message 6 of 8
(4,890 Views)
Hi Siju,
please let me know, which types of interface your Firewire card have. if its a PCI and/or USB, then you can use window API to get PCI bus No. and/or USB bus no. (I am not sure about USB)
i think this will help you.
Alpesh Prajapati
Message 7 of 8
(4,862 Views)
Pls tell which dll to use and which function to get the bus no.  ?
Message 8 of 8
(4,850 Views)
