Machine Vision
logitech usb web camera
hi...
I have downloaded a file from the labview discussion forum, filename: lv_vfw.zip. This file enable the real-time image capture for web camera, it work fine but when i try to web-enable this program, the image window does not appear in the other pc, what happen?what should i do to allow another party (pc) to have the image?
(3,657 Views)
Are you using Remote Panels with LabVIEW to "web enable" your image? If so, you should be using NI-IMAQ 2.6. The WindDraw window that comes with the Vision module for LabVIEW doesn't work with Remote Panels; you should be using the new embedded front panel image display instead.
I'm not sure where exactly you got the driver for the USB camera, but I'm pretty sure it didn't come from NI. You should probably work with whomever provided the driver.
Good Luck.
Kyle V
(3,657 Views)
