Machine Vision
long writing time
hi friends,
in my mtech project i made a image using some calculation.but when i want to write it into an image, needs a long time why?
regards
ragil
IamAKR
(6,123 Views)
Because you are doing it 1024 * 768 times!!!!!!
-How you are calculating time?
-How much is long for you?
-How much time you got?
uday
(6,118 Views)
40 minutes.... to write!!!!!
IamAKR
(6,115 Views)
but to read this image instead of writing i took only 5-10 sec!!!!
IamAKR
(6,112 Views)
Did you read my comment?
-My first statement should give you hint(You are using IMAQ write 1024*768-which is in inner loop)
-How you calculated time?
uday
(6,107 Views)
yes... i am calulating time by when my writing is over in image display( or in writing file). I know there will 1024*768 calculation taking place. my qstn is it will reqiure this much (40 min) to computaion. IF no then wats the problem?
thanks
ragil
IamAKR
(6,105 Views)
Accepted by topic author RAGIL
It is not only calculations you are doing in that loop, you are doing image writing also for each and every iteration.
-Instead you need to use imaq write only once.
uday
(6,102 Views)
