Machine Vision
<IMG_ERR_NOEM> not enough onboard memory...
IMG_ERR_NOEM error message when trying to acquire image with a PCI-1409 in CCIR mode using MAX 2.2.0.30.10.
Diagnostics reports DSPFPGA Register test and Scarab register test failed.
Any ideas?
(2,990 Views)
Sounds like you have a bad board. Please goto ni.com/ask to generate a service request number and call the technical support line with the serial number of your board and we'll be more than happy to help you RMA'ing that board.
Yusuf C.
Applications Engineering
(2,990 Views)
If switch on cameras after PC then error message is IMG_ERR_NOEM
(2,990 Views)
