Machine Vision
make calibration to image without using vision assistant
Hi every one
I want to make calibration to image from front panel while the program running
I achived to enable user to draw line or draw to points on image , then the program return the distance between two points or the line lenght
my calibration is linear and very simple
I tried to use (IMAQ set simple calibration 2.vi) but I didn't know, what I should connect to( x step & y step) terminals
can any one tell me how to solve this proplem or give me some advises
Message 1 of 11
(6,610 Views)
If you are new to LabVIEW, I would recommend that you create a calibration script in Vision Assistant, and then use the export to LabVIEW functionality to save the steps as a VI.  Then you can have a look, and adpat it to your needs.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
Message 2 of 11
(6,604 Views)
Why not use vision assistant?
Message 3 of 11
(6,594 Views)
I build code that run in real time, so I have to build code using low level blocks
Message 4 of 11
(6,592 Views)
I open front panel after making calibration in vision assisstant but, I can't understand how to enter distance value between two pointsmake calibration
Message 5 of 11
(6,590 Views)
X step and y step are to be determined by your image. can you post an image that you want ot be calibrated?
Message 6 of 11
(6,589 Views)
using simple calibration model, you realize that you disregard the lens distortion? It is also advisable that the camera is perpendicular to the inspected object. Here, a telecentric lens helps too.
The simple calibration performs direct conversion from pixels to real-world units. For example, if you know a real world object that you measure is 10 mm in size and it occupies 10 pixels on the image, then the conversion factor is 10mm/10pix = 1mm/pix.
So, you want to measure an object with size U (in pixels), you use the equation:
X = 1mm/pix * U (note that this is for horizontal direction, vertical direction is analogous)
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
Message 7 of 11
(6,580 Views)
 After I made calibration I connect image to some sequential operation image subtraction, edge deteection, threshold, basic morphlogy and advanced morphology
after that I connecte image to vision assistant that contain only particle analysis, but I found that real world parameters not active
Message 8 of 11
(6,543 Views)
do you apply the calibration to the image using IMAQ Set Calibration Info (prior to any analysis)?
K
Message 9 of 11
(6,540 Views)
Dear Klemen
I use (IMAQ set simple calibration then IMAQ set calibration axis info )
then image enter to some image processing function finally enter particle measurment
particle measurment calibration valid indicate true, but real world measurment still not change
Message 10 of 11
(6,532 Views)
