Machine Vision
making imaq window child of window panel
I try with api's set parent,Like the example of ni-zone MAKECHILD it doesnt work,correctly.
Thank you for all.
(3,375 Views)
What programming language are you using? If it is LabVIEW, have you tried running just the example to see if it works? If so, what exactly isn't working correctly? A little more info please...
(3,375 Views)
I use LV6i (french version) , NI-IMAQ 2.5 ,IMAQ Vision
I try the example IMAQ Read file in child Window.vi from Embed WindDraw Window.llb (NI-ZONE).
This example dooesn't work correctly :
- when calling makechild.vi it return 6002 ,the call of FindWindowA API return 0.
Same problem with Fancy Child Example.vi.
(3,375 Views)
I had exactly the same probleme with the same configuration,
Do you managed to solved your problem? how?
thanks
(3,375 Views)
