Machine Vision
migration VBAI script to Labview
I prepared a Vision Builder script and migrated it to Labview. I got the following attached prompt when I try to open the migrated Labview application. Because it couldn't find the calibration data located in Configuration Files folder, the application does not work properly. Where exactly should I copy the "Configuration Files folder" to be able to run the migrated software properly? Thank you for the answers in advance.
Message 1 of 1
(1,561 Views)
