Machine Vision
modify size of user input button on VBAI
In my program (VBAI 2010) I use a user input tool with a tactile screen but the size of the button is a little bit to small.
Is it possible to modify this size (in the configuration file for exemple)?
Thanks for your answer
(3,288 Views)
No good way to modify the size of the button (besides making the text longer so the button is longer). If you need to customize the popup, I would recommend making a Run LabVIEW VI that can you can make look however you want and then run this VI from a Run LabVIEW VI step (you will need to make sure the front panel is opened). Here is a simple inspection with a simple VI to illustrate this.
Hope this Helps,
Brad
(3,282 Views)
Thanks for your answer. I will use your custum VI.
(3,266 Views)
