Machine Vision
motion sensor
hi there, i got a few problems regarding motion sensor
first is how do i calculate the distance and the angle for my motion sensor which currently using PIR sensor.
then if i connect to a DAQ, how do i join all this with my thermocouple and LDR sensor.
thanks in advance
(5,388 Views)
your post quite unclear about what you are trying to achieve.
What angle, what motion are you trying to caclculate? What is your setup? What is your goal?
Please give some more information.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,376 Views)
as in im need to find out the distance and angle of my motion sensor, and also now how can i use a Elapsed Time to actually count the timmer? or how does a Elapsed time help??
my project is about home motioning system which using a wireless device to control and also using teamviewer to control.
my project consist of LDR, MOTION SENSOR and THEMOCOUPLE.
(5,205 Views)
