Machine Vision
my camera image is stretched
I am using a pci-1405 and a sony analog camera.
i set up all the necessity configuration on MAX for the camera, however, I got a vertically stretched image.  I checked and changed Acquisition window setting, but it did none.
I found the following information about aspect ratio, but my pci-1405 dose not have “advanced” tab.
does anyone know how to get the right image?
(3,707 Views)
In max check whether you are using it in the field mode.Change it to frame mode(likely).Let me know if the above thing is not the case
(3,694 Views)
Having the same problem and i am using it in frame mode.Help plz
(3,670 Views)
Hey jany,
               Good i had this issue but just to confirm can you post your stretched image?
(3,659 Views)
