Machine Vision
no interface found
(4,334 Views)
Make sure you go into MAX, check if your camera has been detected and verify the interface name of the camera. That should be the interface name you use in LabVIEW.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,330 Views)
Thank you! But look, the same problem occured as before, even I have ensured the interface of USB device consistent with Front Panel. What had happened?
(4,320 Views)
I believe you are using the wrong driver to communicate with your camera. You need to use the IMAQdx drivers which should be located in the same palette as the IMAQ drivers. If you are not able to find them, then you check whether you have the Vision Acquisition Software installed. Please have a look at the following link:
What is the Difference Between Vision Software VDM, VBAI, and VAS?
Adnan Zafar
(4,307 Views)
