Machine Vision
object detection Methods
      what are the latest methods that are currently involved for object detection puposes?.
Thank you
(4,692 Views)
the best database to satisfy your question is the internet. There are a lot of papers out there that deal with the issue of object detection and tracking. I think this question is hard (or impossible) to answer, since there is no universal algorithm that would perform the same, no matter what the object is.
I think the more relevant question is (if you are trying to develop some algorithm of your own):
What are your goals, constraints, measuring setup, components price range, etc...?
I could recommend the following book:
Computer Vision: Algorithms and Applications (Texts in Computer Science)
and
Learning OpenCV: Computer Vision with the OpenCV Library
But if you want to get the latest on detection, you should check out recent published papers in computer vision.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(4,677 Views)
