Machine Vision
object tracking calculate distance
I want to track an object and plot its distance moved with respect to time on an xy plot.  I am using the example vi "Object Tracking" as a base for my project.  I have an express xy plot, but even when I try plotting constants nothing shows up.  I attached the vi to this message.  Any help would be much appreciated!
(4,640 Views)
you have limited the help to only the people that have Labview 2014. Can you save it for one of the previous versions (I have Labview 2013, but perhaps 8.6 would be even better if posssible)?
Or, can you attach a screen-shot of your code, where the problem occurs.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(4,637 Views)
