Machine Vision
openCV NI1722 Camera
I try to use the openCV library in labview using a DLL wrapper.
I need openCV library beacause i try to implement an optical flow algorithm.
If I use the library with labview, can i "download" the .vi to the smart-camera???
(5,538 Views)
The NI 17xx Smart Cameras run LabVIEW RT on top of VxWorks on a PowerPC processor. It is possible to interact with compiled libraries through LabVIEW but you'd have to cross-compile the library using GCC for VxWorks and Power-PC. If you search around you'll see there are guides to setting up a compatible toolchain for targets such as the CompactRIO that will work for the Smart Camera as well....
However, this all rests on OpenCV being able to compile for PowerPC processors. From some quick research, the codebase seems to have a lot of x86 assembly and is not likely an easy port to PPC/VxWorks.
That said, you could always use the NI Vision Development Module for your algorithm. Are there any shortcomings in what is offered that you have chosen OpenCV instead?
Eric
(5,536 Views)
Ni Vision doesnt have any ready optical flow algorithm.
Instead, openCV has a ready optical flow algorithm and also it has mush more documentation
(5,533 Views)
If form factor is not an issue, you could use the CVS or the new Embedded Vision System with a seperate camera and try to use OpenCV with that instead. Both of these platforms are x86-based and you'd likely have a lot less trouble interfacing with the OpenCV DLL.
Eric
(5,529 Views)
Would it be difficult to create an optical flow algorithm from scratch in Labview using Vision and IMAQ?
Message Edited by grekop on 06-10-2009 03:45 PM
(5,527 Views)
So, if i write any DLL in Visual C++ and connect it into a VI, i can't download the VI to the smart camera?
(5,484 Views)
Correct. Visual C++ can only output x86 binaries. The Smart Camera and newer cRIO devices use a PPC processor. There are several instructional articles around (such as this one: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x4puCAA&l=en-US) that explain how to compile the VxWorks equivalent of DLLs using the GCC toolchain. After building the binary you can link to it within your VI just like a DLL on other platforms.
Hope this helps,
Eric
(5,471 Views)
