Machine Vision
overlay transparency v2 Need help!
Please tell me how to save the "overlay plus background" image to a file ? When I tried to do this, only the background image was saved in the file.overlay transparency v2_vi Block Diagram.jpg
(2,818 Views)
Accepted by topic author VSD
Hi VSD ,
 You only "overlay" a picture in original picture and if you want to save it with that picture, you need to use "IMAQ Merge Overlay VI" before save it. Sometimes we use your requirement to verify the vision process result. It's common way we will use in AOI machine.
Thanks.
Ricky
(2,754 Views)
Dear Ricky! Thank you very much! Your help is very valuable to me.
(2,742 Views)
