Machine Vision
particle analysis report - getting the rectangle coordinates of each particle
Hello all,
I tried to extract the the rectangle coordinates for each particle after Particle Analysis Report but without success till now. Any help would be appreciated.
Thank you very much.
IG.
Message 1 of 14
(5,280 Views)
Message 2 of 14
(5,279 Views)
what does 4 mean in the picture... the number of the particle for which the array of coordinates will be displayed?
Message 3 of 14
(5,277 Views)
Nope. It represents Top,Left and bottom,Right
Message 4 of 14
(5,276 Views)
yeap, but in this way I am extracting only the coordinates of the first particle, right?
Message 5 of 14
(5,275 Views)
Simple use a for loop like this.
Message Edited by muks on 08-10-2009 04:57 PM
Message 6 of 14
(5,270 Views)
well, I still have the same problem and i am only getting the coordinates of the first parcile and the for loop is executed only once..i can't it figure it out where exactly u tell labview which particle coordinates should be considered ?
Message 7 of 14
(5,267 Views)
Please bring the buffer (imaq create) inside the for loop as mentioned above. Now I dont tell labview which particle has to be extracted. I am extracting all the particle. If you want to select a particular particle use an index array inside the for loop.
Message 9 of 14
(5,261 Views)
 i guess it runs too fast and i can't follow it 🙂
Message 10 of 14
(5,260 Views)
