06-06-2005 01:55 AM
06-06-2005
03:53 PM
- last edited on
09-14-2026
06:26 PM
by
Content Cleaner
Sundar,
This is exactly what the Vision Development Module is designed for. If you do not have this software package, I would highly recommend getting it for this project.
Take a look at the pattern matching example program which installs with the Vision Development Module under:
C:\Program Files\National Instruments\LabVIEW 7.1\examples\Vision\2. Functions\Pattern Matching
Also Vision Assistant has a number of pattern matching examples in the Solutions Wizard. Look at Electronics >> Printed Circuit Board solution. It performs two pattern matches with two different templates.
Hope this helps. Good luck with your project!
