Machine Vision
pattern matching program
Thanks for your help! The program you sent me does not take the image selected an use it as a template for the uploaded video. I don't know if I'm just doing something wrong... Also, how can I optimize my program??
Message 11 of 57
(6,958 Views)
Hi frog dont worry.. I will do for u..
Silver_Shaper | CLD
Message 12 of 57
(6,952 Views)
Thanks! Let me know what you come up with!
Message 13 of 57
(6,949 Views)
Accepted by topic author frog7
Hi Frog,
Find the attached vi and Video. This will help you..
Don't forget to Mark solution accept, if problem is solved.
Silver_Shaper | CLD
Message 14 of 57
(6,941 Views)
Hi frog..
Did you checked it out?
Silver_Shaper | CLD
Message 15 of 57
(6,937 Views)
Thank you, the program looks pretty cool, although there are three sub VI's that are not found in the download.  do you happen to have access to these VI's?
Message 16 of 57
(6,488 Views)
hi. Actually I modified the built in example. that's why it's missed. open pattern matching program in vision example of labview. so that you can get the subvi.
Silver_Shaper | CLD
Message 17 of 57
(6,483 Views)
where can I find the Vision example program?   I apologize for the lame question, I'm rather new to lab view use
thank you for all your help
Message 18 of 57
(6,482 Views)
go to NI example finder available in tools menu and you can find search box. search for pattern matching program over there. let me know your problem solved.
Silver_Shaper | CLD
Message 19 of 57
(6,480 Views)
Thank you,  I believe I found the search box you were refering to, and I did a comprehensive search of my entire hard drive, and found no such pattern mapping program.  Am I using the wrong finder box perchance?  I have lab view 2011.  under the tools bar for the front panel I selected the "Find VI's on disk" option.  that is what I used to conduct the inconclusive search.  thank you for your patience with my negligence.
-Gideon7
Message 20 of 57
(6,476 Views)
