Machine Vision
pb detection two cameras GigE with MAX on the same pc
I installed on the same pc two GigE camera, each camera has its own interface card  (IP), but only one camera in dtected with max.
sometimes cam0 and sometimes cam1.I have to carry out has each camera a fixed address IP but always only camera is detected.
my question is how to make the configuration to appear both camera at the same time with max.
I use the MAX version 5.3
NI IMAQDX 4.0
Think you very match for your help.
Hamd2015
(3,599 Views)
Hi Hamden,
Could we get a little more information about your setup as it will help narrow down the issue?
- What network interface cards (NIC) are you using?
- What cameras are you using?
- Are we running the cameras through a network or directly connecting them to the computer?
- Can we see each camera when plugged in individually?
- It sounds like you said that you are using a static IP address, but I wanted to confirm this.
- Can we see both NICs in Windows Device Manger?
Bill E. | Applications Engineer | National Instruments
(3,586 Views)
Accepted by topic author Hamden
Are you running Windows XP? If so, due to limitations in the underlying OS stack, you'll need to either put the cameras into different subnets or bridge the two NIC devices together into a single virtual device (preferred).
Eric
(3,584 Views)
Think you for your answer.and i'm sorry for my english
Exllent, it works with bridge vertuel (pont)
I checked the right fonctionnemt!
Hamd2015
(3,575 Views)
