Machine Vision
pci-1428 camera link interface
How do I control the camera link CC(n) lines, using labview, triggered?
Thanx.
(3,226 Views)
Hello.
The CC lines on the PCI-1428 are camera link data/control lines. These lines are not specifically 'controllable.' The way they are used is definied in the camera file (*.icd). Depending on which camera you have, you will select a different one of these camera files. To select the camera file, open up Measurement and Automation Explorer (MAX), expand Devices and Interfaces, expand the PCI-1428, and then right-click on the channel and select 'Camera.' If the camera you are using is not present, then there may not be a camera file installed on your system for your camera. There are some additional camera files located at the following FTP address:
Digital Camera Files: FTP Site
Hope this helps you out!
Colin C.
Applications Engineering
Colin Christofferson
Community Web Marketing
Blog
(3,226 Views)
