Machine Vision
pci-can/2 series 2
Hello!
The problem first show up when I wanted to try my program. When i clicked RUN
windows freezed. So i restarted the pc and whnen the OS was booting it freezed
again. In safe mode I uninstalled NICAN files and then pc normally boot up.
Ofcourse my program didn't work (depends on can bus)so I tried to install nican
driver. There wasnt problem with nican libraries anymore, but in the
hardware the driver for pci-can module was not installed.
The question is:
What is the problem: pci-can or soft?
Software: LabVIEW 8.6
NI Hardware:  CAN device PCI-CAN Series 2
OS:  Windows XP
(4,956 Views)
Dear mgolec,
this board is dedicated to machine vision problems, not hardware interfaces for communication protocols.
Please continue the discussion here: http://forums.ni.com/t5/Automotive-and-Embedded-Networks/PCI-CAN-2-s2/m-p/3013571#M7061
(4,925 Views)
